Read .h3d Node Positions
Use the Read Positions tool to read .h3d node positions.
For every task, with the exception of creating a table, once the solver run is finished you will import the new node positions, and in the stitching the new connectivity, from the .h3d file generated.
                From the Airbag ribbon, click the satellite
                    icon
 that appears
                    when you hover over the tool.
             - Enter a File name (.h3d file) and click Open.
