Create a Roll Fold
                From the Airbag ribbon, click the
                        Roll tool.
Figure 1. -
                On the guide bar, click
                - Tool Type: Select the tool around which the airbag will be rolled. This can be either a flat strip (width) or a cylinder (diameter).
 - Number of rotations: The computation stops once this number is reached or a stopping position is reached.
 - The checkboxes allow you to define some boundary conditions. In most cases, you will want to keep the default of the activated checkboxes.
 - Create Symmetric Folding: Create a symmetric roll fold. After the component selection a microdialog opens to create the symmetry plane. Click Create in the microdialog. Two fold lines representing rolling tools are created, one initial and one symmetric.
 - Folds Directory: The location where the results of the run are written.
 - On the guide bar, click Components.
 - Select the airbag components.
                Set advanced selections as necessary by clicking
 on the guide bar.
                On the guide bar, click Stop
                        Position. In the case of a symmetric fold select Stop
                        Position according to the initial fold line. The stopping
                    position for the symmetric fold line is calculated automatically.
                This requests a node to be selected, and then a rigid shell plane part generates at this position, enabling the rolling to stop and the computation if reached.
 - On the guide bar, click Export to export the pre-simulation model to be run.
                At the end of the pre-simulation run, click the satellite icon
 to load the new
                    positions from the resulting .h3d file.
