Create a Zig Zag Fold
                From the Airbag ribbon, click the
                        ZigZag tool.
Figure 1. -
                On the guide bar, click
                - Method: If you select method2 the upper and lower plates move. If you select method1 only the lower plates move.
 - Total No. of Plies: The total number of plies.
 - Lateral Distance: Specify the position of the plates perpendicular to the folding direction.
 - Width (Fixed Plate): The width of the plates.
 - Folds Directory: The location where the results of the run are written.
 - On the guide bar, click Components.
 - Select the airbag components.
                Set advanced selections as necessary by clicking
                    on the guide bar.
             - On the guide bar, click Side.
 - Select a node for defining the side of the folding.
 - On the guide bar, click Export to export the pre-simulation deck.
                At the end of the pre-simulation run, click the satellite icon
 to load the new
                    positions from the resulting .h3d file.
