Fit Airbag to Housing/Container
Use the Housing tool to fit the airbag to housing/container.
                From the Airbag ribbon, click the
                        Housing tool.
Figure 1. -
                On the guide bar, click
                - Folds Directory: The location where the results of the run are written.
 - On the guide bar, click Components.
 - Select the airbag components.
                Set advanced selections as necessary by clicking
 on the guide bar.
             - On the guide bar, click Container.
                Select the target container of the airbag.
                Once completed, a copy of the container appears. You have to position it in order to have it fully enclosing the airbag without any intersection.
 - On the guide bar, click Export to export the pre-simulation model.
                At the end of the pre-simulation run, click the satellite icon
 to load the new
                    positions from the resulting .h3d file.
