FRAC - Load Tab
The FRAC utility's Load tab allows you to select and load the reference and correlation files to prepare them for a FRAC analysis.
Figure 1. FRAC Utility - Load Tab
The following options are available:
File Selection
- H3D (*.h3d)
 - OP2 (*.op2)
 - PUNCH (*.pch)
 - UNV (*.unv)
- Ref and Cor Subcase
 - Use the Ref Subcase and Cor Subcase drop-down menus to select loadcases for filtering.
 - Frequency Filter
- Start and End Frequency
 - Enter a start and end frequency range and click Select to filter the frequencies in that range.
 - Correlation Interpolation
 - Select interpolation methods to be applied to the reference or correlation frequency response results.
 - Response ID Selection
 - Select the response IDs and types for FRAC and FDAC calculation.
