PreTest
PreTest allows prediction and optimization of the sensor locations (accelerometers) for measurements and directions along with test excitation point location, a very important step in the experimental modal analysis process directly affecting the accuracy of test results. Driving point residue (DPR) calculation gives information on optimum point for excitation location.
- H3D – binary result file typically generated using OptiStruct.
 - OP2 – binary result file typically generated using OptiStruct or Nastran.
 - ODB - binary result file typically generated using Abaqus.
