Grid Participation
The Grid Participation utility allows you to plot panel grid participation results and then use advanced scaling contour capabilities to isolate key contributing areas.
- OptiStruct.h3d file
 - PFGRID.h3d - which contains the participation data output, as well as information regarding the fluid-structure grids and elements.
 - MSC Nastran .op2 file
 - PFGRID.op2 – which contains the participation data output, as well as information regarding the fluid-structure grids and elements.
 - OptiStruct punch file
 - PFGRID.pfmode.pch – which contains the participation data output.
PFGRID.interface - which contains information regarding the fluid-structure interface grids and elements.
