| Distance Between |
                        The distance between two nodes or two systems (markers).
                                    - Guide bar Method
                                    - Pick entities graphically or input the IDs. One measure item
                                        is created for every pair and assigned its own measure group
                                        (default). If the “Auto Group” check box under the Options
                                        menu is selected, then all items are put under a single
                                        group.
                                    - Browser Method
                                    - Create a measure group first, set the type to Distance
                                        Between and then using the Pick Entities field, create and
                                        add as many items to the group.
Note: When this measure type is resolved in a
                                cylindrical or spherical user system, the graphical user interface
                                automatically changes to display Magnitude, R, T, Z or Magnitude, R,
                                T, P. The component values are simply calculated as the difference
                                between the component values of the two entities.
                        | Minimum Distance |
                        The minimum (or shortest) distance between two entities.
                                    - Guide bar Method
                                    - Pick From and To entities using the selectors. Once the
                                        selections are finalized, click the
                                            Create button to create a measure
                                        item. One measure item is created for every pair and
                                        assigned its own measure group (default).  If the “Auto
                                        Group” check box under the Options menu is selected, then
                                        all items are put under a single group.
                                    - Browser Method
                                    - Click the Entities button to display
                                        the Minimum Distance dialog.
Use the
                                                 From and
                                                 To input collectors to
                                            select, or change, the type of entity that will be added
                                            to a measure group. You can then pick entities to be
                                            measured directly from the screen, using the quick
                                            window selection, or by clicking the
                                                 Elements,
                                                 Components, or
                                                 Nodes input collector and
                                            using the extended entity selection menu. See the  Select Entities Using the Input Collector
                                            topic for more information on selecting entities. Tip: The From collector
                                                will always pick nodes (only) on the selected part,
                                                and the To collector will either pick nodes or
                                                elements on the selected part. For faster
                                                computation, it is recommended to use to Nodes for
                                                both collectors. When defining From or To sides,
                                                  picking entities from more than one model is not
                                                  allowed. A warning message will be displayed and
                                                  you will have to redefine the
                                        set.
Activate the Save set check box to save
                                the measure groups as a set. See the Sets
                                Panel topic for additional information.
                                Tip: Check the Notes
                                    section below to understand how to Edit or Review a minimum
                                    distance measure.
                                    interface automatically changes to display Magnitude, R, T, Z or
                                    Magnitude, R, T, P. The component values are simply calculated
                                    as the difference between the component values of the two
                                    entities.
                        | Incremental Distance |
                        The incremental distance between two nodes or two systems (markers).
                            The incremental distance gives the relative change in distance between
                            two points. It is calculated by taking the distance between two entities
                            (at the current time step) and subtracting the distance between (at the
                            relevant frame, or time step, depending on the animation mode as defined
                            below). The change of length is displayed.
                                - In transient animation mode, the incremental distance is
                                    relative to the time step at which the measure is defined. The
                                    change in distance between two points is tracked relative to the
                                    time at which the measure is defined.
                                - In linear or modal animation mode dealing with real data, the
                                    incremental distance always gives the change in distance between
                                    two points with respect to the undeformed configuration.
                                - In modal animation mode with complex data, the incremental
                                    distance is relative to the frame/angle at which the measure is
                                    defined.
                                    - Guide bar Method
                                        group.
                                    - Browser Method
                                    - Create a measure group first, set the type to Incremental
                                        Distance and then using the Pick Entities field, create and
                                Attention: In the case of
                                    incremental distance, Magnitude is
                                    calculated as the change in magnitude value between the current
                                    frame and reference frame and is not calculated from the
                                        X, Y, and
                                        Z components.
                        | Position |
                        Available for nodes or systems (only). Provides x, y, and z
                            coordinates at any given time frame.
                                    - Guide bar Method
                                    - With Auto Create enabled, pick entities graphically or input
                                        the IDs. One measure item is created for every entity picked
                                        and assigned its own measure group (default). If the “Auto
If you want to
                                            first select many entities and then create measures for
                                            all of these entities in a single click, then disable
                                                Auto Create, pick the desired
                                            entities, and click the Create
                                            button. This will also put all the created measure items
                                    - Browser Method
                                    - Create a measure group first, set the type to Position and
                                        then using the Pick Entities field, create and add as many
                                        items as possible to the group.
                        | Relative Displacement |
                        The distance of a node at any given time relative to a position at
                            the time the measure item is defined. The options, Magnitude, X, Y, and
                            Z, allow you to display the designated value for each selected measure group
                                    - Guide bar Method
                                        the IDs. One measure item is created for entity picked and
If you want to
                                    - Browser Method
                                    - Create a measure group first, set the type to Relative
                                        Displacement and then using the Pick Entities field, create
                                        and add as many items as possible to the group.
                                    as the change in component values between the current frame and
                                    reference frame.
                        | Relative Angle |
                        The angle between the new N1 N2 direction versus the original N1 N2
                            direction defined at the time the measure is created (T1). The display
                            options are True angle, X-projection, Y-projection, and Z-projection.
                            The X-projection option displays the projected true angle onto the
                            plane, with the x-axis as the normal. The Y-projection and Z-projection
                            options act in a similar manner.
                                    - Guide bar Method
                                        group.
                                    - Browser Method
                                    - Create a measure group first, set the type to Relative Angle
                                        and then using the Pick Entities field, create and add as
                        | Angle Between |
                        The angle between three nodes (N1, N2, and N3) or three systems
                            (markers). Three nodes/markers are required to define the measure. The
                            display options are True angle, X-projection, Y-projection, and Z-projection.
                                    - Guide bar Method
                                        is created for every three entities picked and assigned its
                                        own measure group (default). If the “Auto Group” check box
                                        under the Options menu is selected, then all items are put
                                    - Browser Method
                                    - Create a measure group first, set the type to  Angle Between
                        | Incremental Angle |
                        The incremental angle between three nodes (N1, N2, and N3) or three
                            systems (markers). Three nodes/markers are required to define the
                            measure. The incremental angle gives the relative change in angle formed
                            by the three points. It is calculated by taking the included angle of
                            the three points (at the current time step) and subtracting the angle
                            between (at the relevant frame, or time step, depending on the mode of
                            animation as defined below). The change of angle is displayed.
                                - In transient animation mode, the incremental angle is relative
                                    to the time step at which the measure is defined. The change in
                                    angle is tracked relative to the time at which the measure is
                                    defined.
                                    incremental angle always gives the change in angle with respect
                                - In modal animation mode with complex data, the incremental angle
                                    defined.
The display options are True angle, X-projection, Y-projection,
                                and Z-projection.
                                    - Guide bar Method
                                        group.
                                    - Browser Method
                                        Angle and then using the Pick Entities field, create and add
                        | Circle radius |
                        The radius and center point of a circle defined by three nodes or
                            three systems. The display options are Radius, Ctr X, Ctr Y, and Ctr Z.
                                    - Guide bar Method
                                        group.
                                    - Browser Method
                                    - Create a measure group first, set the type to Circle Radius
                        | Yaw Pitch Roll |
                        The angular rotational displacement of a system (marker) around the
                            z-axis, y-axis, and the x-axis is defined. The display options are Yaw,
                            Pitch, and Roll.
                                    - Guide bar Method
                                        group.
                                    - Browser Method
                                    - Create a measure group first, set the type to  Yaw Pitch
                                        Roll and then using the Pick Entities field, create and add
                        | Nodal Contour or Elemental Contour |
                        When a contour has been applied to the model, an additional measure
                            option is available. Nodal Contour is added if the contour contains
                            nodal results; Elemental Contour is added if the contour contains
                            elemental results.  For each of these measure types, you can display
                                the nodal or elemental values of the selected nodes or elements by
                                activating Value.
                                    - Guide bar Method
If you want to
                                    - Browser Method
                                        Nodal/Elemental Contour and then using the Pick Entities
                                        field, create and add as many items as possible to the
                                        group.
If the contour is based on a MaxLayer/MinLayer/ExtremeLayer,
                                then the Value displayed consists of two parts: a “Value =” display
                                that gives the actual value extracted across all layers that is a
                                Max/Min/Extreme respectively, and a “Layer=” display that provides
                                the layer name corresponding to the Max/Min/Extreme value. This is
                                useful in identifying the significant ply and its value at the same
                                time. Any curves generated from the Create
                                    Curves button will be plotting based on the number
                                associated with “Value=”.
An additional Envelope Subcase check
                                box is available if the contour belongs to an Envelope derived load
                                case. This option will only be displayed in the panel if the
                                Envelope function is not of the Range type.
Activating
                                     Envelope Subcase will display the subcase
                                to which the value belongs in the case of a subcase trace plot, and
                                the subcase/simulation to which the value belongs in the case of a
                                Simulation or None trace plot. Note: Starting
                                    in version 2019, Value will display the underlying numeric value
                                    irrespective of whether the Envelope trace plot is set to None,
                                    Subcase, or Simulation. Older session files that use Value to
                                    display subcase or simulation will be updated to use the
                                    Envelope subcase check box instead when loaded in version
                                    2019.
                        | Node Path |
                        Two or more nodes are required to define this measure. The nodes
                            located in the path between the selected nodes will be automatically
                            selected. You can continue to select nodes in the model to define a path
                            from which you would like to extract the contour results in order to
                            create a plot. The options, Value and
                                Distance, allow you to display the value and
                            distance magnitude for nodes. Distance displays
                            the distance from the first node to each node along the path. Nodes on
                                a cross-section can be selected for defining a path along the
                                cross-sections. This is useful in measuring the variation of a
                                result, for example the blank thickness in stamping simulation,
                                along a section cut. There are however, certain restrictions on
                                selection and interchangeability of paths on regular model nodes to
                                section cut nodes.
                                        - Guide bar Method
                                            item is created for every pair and assigned its own
                                        - Browser Method
                                        - Create a measure group first, set the type to Node Path
