Add an FMU Entity
- Select the system to which the FMU entity is to be added.
                Add the FMU entity to the system by any of the following methods:
- From the Model ribbon, click the FMU icon.
 - Right-click on the system in the Project Browser and
                            select Add > Control Entity >
 FMU from the context menu.  - Right-click on any existing FMU folder in the Project Browser  and select
 Add FMU… from the context
                            menu.
The Add FMU dialog is displayed. -
                Specify a label and a variable name.
                Note: By default, variables names of entities in MotionView follow a certain convention. For example, all FMU entities have a variable name starting with “fmu_”. This is the recommended convention to follow when building models in MotionView since it has many advantages in identifying the entity during model editing and model manipulation
 - Use the Filename browser to locate the FMU file (.fmu) and select it.
 - Click OK to close the window or Apply to continue creating entities.
