Solver Differential Equations
Use the Diff Equations tool to set solver differential equations. These equations can be used to add additional states to the mechanical system being modeled.
Create Solver Differential Equations
Edit Solver Differential Equations
Use User-Defined Properties for a Solver Differential Equation
If desired, define the solver differential equation using the User-Defined tab, which will allow you to specify the properties of the equation using user subroutines.
- From the Properties tab, click the User-defined properties check box.
 - Click the newly added User-Defined tab.
                Define the user subroutine.
