Surfaces
Use the Surfaces tool to create and edit surfaces.
Create Surfaces
Edit Surfaces
The surface entity allows you to describe a parametric surface for use with advanced joints like point to surface joints, curve to surface joints, and the surface to surface joints. The surface can be described by a user subroutine for the MotionSolve and ADAMS solvers, and by a Parasolid reference for the ADAMS solver.
User-Defined Properties for a Surface
If desired, define the output using the User-Defined tab, which will allow you to specify the properties of the surface using user subroutines.
- From the Connectivity tab, activate the User-defined properties option.
 - Click the Properties tab.
 - Enter the initial and final values in the U and V directions.
 - Click the User-Defined tab.
                Define the user subroutine.
