A polybeam has circular cross sections throughout its length. The mass of the
        polybeam is distributed across dummy bodies that are located at each point in the polybeam.
        A polybeam is defined by specifying the cross-sectional properties of the beam and the
        locations of the points in the beam. MotionView automatically
        generates the actual beam elements and dummy bodies.
                If the Polybeams panel is not currently displayed, select the desired polybeam
                    by clicking on it in the Project Browser or in the
                        modeling window.
The Polybeams panel is automatically displayed.
                From the Point Connectivity tab, click the Point
                    collectors and select the points that describe the polybeam from the modeling window, or double-click the collectors to open the
                        Model Tree (from which the desired points can be
                    selected).
                    Tip:
                            - To add points to the end of the table, enter the number of points
                                you want to add in the text box and click
                                    Append.
                            - Select the check box next to any point and click
                                    Insert to add a new point above the point
                                selected.
                            - Delete points by selecting their respective check boxes and clicking
                                    Delete.
                Click the Beam Properties tab.
By default, the polybeam has a circular cross section.
                Enter a value for the mass density (Rho) of the material of the beam.
                Enter the values for the Young’s Modulus (E) and Shear Modulus (G) in the
                    corresponding fields.
                Enter the values of the Outer (OD) and Inner Diameters (ID) of the polybeam
                    cross section.
                Enter a value for the correction factor (AS) for the shear deflection.
                Enter a value for the stiffness to damping matrix ratio (CRatio).
The damping matrix for the polybeam is computed by multiplying the stiffness
                    matrix by the C ratio.
                If needed, click the Point Coordinates tab and edit the
                    coordinates of points in the X, Y, and Z directions.
