From the Properties tab, you can define the contact method and the properties for the
        option type selected.
                Click the Properties tab.
                Select the desired method and define the related properties.
If Linear is chosen:
                        Enter a value for the radius of the sphere that the deformable surface
                            will be contacting.
                        Enter a value for the stiffness of the contact force.
                        Enter a value for the damping of the contact force.
                If Poisson is chosen:
                            will be contacting.
                        Enter a value for the penalty parameter to determine the local
                            stiffness properties between materials.
                        Enter a value for the coefficient of restitution.
This value represents the energy loss between the two contact bodies.
                            The valid range for this value is between 0.0 and 1.0. A value of 1.0
                            represents no energy loss and a perfectly elastic contact. A value of
                            0.0 represents a perfectly plastic contact and all energy is dissipated
                            during contact.
                If User-Defined is chosen:
                            will be contacting.
                        Enter the user subroutine function expression in the in the User expr:
                            text box.
                        MotionSolve the Use local file
                                and function name check box if the use of a local
                            subroutine file is necessary.
                        Select the subroutine file in the local system by clicking on the
                                Local File: folder icon.
                        From the Function Type drop-down menu, select the type of the
                            subroutine file: DLL/SO,
                                Python, or MATLAB.
                        Enter the function name in the Function Name: text box.
MotionView provides PTDSFSUB as the
                            default, which is the default function used by MotionSolve and ADAMS.
            Tip: For a 3D object, the normals point outward, which represents a typical
                outer surface of a volume. Click Flip normal to turn that
                surface into a void, or "hole".
