A point to curve joint consists of a fixed point on one body sliding on a curve that
        is fixed on a second body. The point is not allowed to lift off the curve. The curve on the
        second body should be a 3D curve and needs to be specified using a MotionView curve (which is a reference entity).
        In order to completely specify a point to
            curve joint, the following entities must be created first:
                - A 2D or a 3D reference curve entity created using the Curves panel.
                - A marker that belongs to Body 2 of the joint and is located appropriately so
                    that the curves entity can be meaningfully described as belonging to the
                    coordinate system of the reference marker.
                If the Advanced Joint panel is not currently displayed, select the desired
                    advanced joint by clicking on it in the Project Browser
                    or in the modeling window.
The Advanced Joint panel is automatically displayed.
                From the Connectivity tab, click Body
                        1 and pick a body from the modeling window, or double-click Body 1 to open the Model Tree (from which the desired body can be
                    selected).
                    Note: In the
MotionSolve solver mode, Body 2 is
                        automatically selected based on the body that the reference marker is
                        attached to.
In the ADAMS solver mode, this
                            body can be selected explicitly.
                Click the Point collector and select the point of the
                    PTCV joint from the modeling window (or pick the point
                    from the Model Tree).
This will be the point that belongs to Body 1 and lies on the curve to be used
                    for the joint.
                Click the Curve collector and select the curve to be
                    used for the joint from the modeling window (or pick the
                    curve from the Model Tree).
                Click the Ref Marker collector and select the curve
                    reference marker that belongs to Body 2.
The Body 2 field will now automatically display the body to which the
                    reference marker belongs.
                Click the Initial Conditions tab.
                Select the User Initial Condition
                        Marker check box and select the desired marker using the Marker
                    collector.
The default initial condition marker for the joint is the reference marker
                    that is specified in the Connectivity tab.
                Select the Use XYZ check box and
                    enter the initial position values into the X, Y, and Z fields to specify an
                    initial position for the point.
                    Note: These values will supersede those specified by the Point collector in the
                        Connectivity tab.
                Select the Use velocity check box
                    and enter a value to specify the initial velocity for the joint.
By default, this marker is set to the joint reference marker that belongs to
                    Body 2.
