Sketch Units
All sketch data and parameter entities are handled according to the current unit system. All dimension values, variable manager values, and sketch entity data like line length, circle radius, or point position are appended with the current units system.
The default unit system is MMKS (mm kg N s). Opening or importing previous HM files containing sketch data are interpreted with this default unit system. Unit systems can be changed from .
- When opening/importing CAD data into a session, you need to choose your target units as what is set in the sketching units.
 - When the sketching unit system is changed, all the sketches and parameter data present in the session are scaled based on the unit system value, including its realized lines and surfaces.
 - Units can not be changed while sketching is in progress.
Grid Spacing
Grid spacing is interpreted from the values specified and the selected unit system.
HyperMesh has five progressive levels of grid spacing, available in . To change the default spacing for a particular grid, enter a value in the text box. Grid spacing for metric and English unit systems are maintained separately.
