New Sketch
Start a new sketch and select a sketch plane.
                Create a new sketch plane by defining a plane.
                        Select one of the global planes.
Figure 1. -
                        If needed, use the Vector tool to modify the
                            plane's orientation.
Figure 2. -
                        Click
 on the guide bar.
                        Once the plane is accepted, the new sketch entity is added and you can
                            start sketching using the Create tools.
Figure 3.
                Create a new sketch plane by selecting a face.
- Change the entity selector on the guide bar to Surface.
                        Select a surface to use as a reference plane.
                            Figure 4.  -
                        Click
 on the guide bar.
Figure 5.
Tip:- For a surface selection, the cursor click location becomes an origin of the sketch plane.
 - At this origin, the plane normal is calculated and intersected with the part that the surface belongs to.
