Point/Lines
Sketch and edit a point, line, polyline, or line-arc.
Sketch Points
Sketch points.
                On the Sketch ribbon, select the
                        Points tool.
 - Select a face or plane as the sketch plane.
 - Click on the sketch plane to place points.
Sketch a Line
Sketch a single line.
                        Line tool.
 - Click twice in the modeling window to define the endpoints of the line, or enter a length in the microdialog.
Sketch a Polyline or Line-Arc
Sketch a line. You can then add line segments to sketch a polyline or add arcs to sketch a line-arc.
                        Polyline tool.
                Click in the modeling window to place the first point of the polyline.
- To add a line segment, click in the modeling window to define the endpoints of the line segment, or enter a length in the microdialog and press Enter.
 - To add an arc:
- Press Shift to turn on arc mode.
 - Hover over one of the blue arrows on the last point you placed to define the direction as Tangent or Perpendicular.
 - Click in the modeling window to place the endpoint of the arc, or enter the arc measure (degrees) in the microdialog and press Enter.
 - To turn off arc mode, press Shift again.
 - Double right-click to end the polyline.
Edit a Point, Line, Polyline, or Line-Arc
Reposition, resize, or apply a sketch constraint.
