Offset/Mirror
Offset or mirror a sketch curve.
Mirror
Create symmetric copies of selected sketch curves across a selected centerline. By default, there is a parent-child relationship between source curves and their symmetric copies.
                On the ribbon Sketch ribbon, select the
                        Mirror tool.
 - Select the sketch entities to mirror.
 - On the guide bar, select Axis.
 - Select an axis or line as the centerline to mirror across.
 - Select Apply on the guide bar or microdialog.
Offset
Create a copy of a sketch curve at a specified distance from the source curve.
