When “Table” is selected, the list of slips to be considered must be defined by using the
field: “Slip table” and then clicking on the button “Set values”.
Two ways are possible to fill the table: either filling the table line by line or by
importing an excel file, where all the slips to be considered are defined.
Note: The slips must be listed in ascending order.
| Slip distribution mode = Table |
| 1 |
Select the “Table” option. |
| 2 |
Click the button “Set values” of the field “Slip table” to open a
dialog box defining the list of slips to be considered. Refer to the
next illustration which shows how to fill the Slip table. |
| 3 |
Button to validate and consider the user inputs |
| 4 |
Button to run the computation |
| Slip distribution mode = Table – Dialog
box to define the list of slips |
| 1 |
Dialog box opened when clicking on the button “Set values” in the
field “Slip table” |
| 2 |
Browse the folder to select an Excel file which defines the list
of slips |
| 3 |
Button to refresh the table data when the considered Excel file
has been modified |
| 4 |
Fields to be filled with data to describe the considered
slips |
| 5 |
Button to apply the inputs |
| 6 |
Button to erase the data table |
Note:
The Excel template used to import the list of slips is stored in the folder
Resource/Template in the installation folder of FluxMotor®. An example of this
template is displayed below.
| Excel file template to define the list of slips |
Note:
- The slips must be listed in ascending order.
- We recommend defining at least 100 values to get an accuracy high enough,
(especially since going below 100 does not lead to a significant reduction in
computation time).
