Generate Custom Refinement Zones
Create an arbitrary refinement zone around a closed volume.
This function is useful in cases where you want to have refinement in a specific shape to capture the flow, such as the wake of a side view mirror. If the part that is selected does not form a closed volume, the mesh within the bounding box of the part will be refined.
Create custom refinement zones in the following ways:
  • Use the Custom tool.
    1. From the Setup ribbon, click the Mesh Controls tool.
    2. From the secondary tool set, click the body of the Custom tool.
    3. Select a part.
      A new refinement zone is generated and the selected part becomes transparent.
    4. Enter a value for Level in the microdialog.
      Figure 3.
      Note: All mesh controls in the model are defined relative to the far field size, and must be a power of 2 of the far field size. For example, if you define a far field mesh size of 1 m, the available refinement sizes will be 0.5, 0.25, 0.125, and so on.
  • Right-click on a part in the modeling window or the Model Browser and select Identify As > Custom Zone from the context menu.
  • Select a part in the modeling window or the Model Browser then change the Identify As field to Custom Zone in the Property Editor.
Tip: Modify the refinement zone's dimensions in the Property Editor.
