You can change the unit system using the Unit System Selector or the Preferences. When importing "discrete mesh" files (.stl, .nas, .fem) with unspecified units, select the model unit in the Import Options dialog.
Use the Identify Parts tool to define types of parts like wheels, heat exchangers or body panels, which require specific modeling techniques
for the CFD run.
Baffles are used to model very thin walls, for example sheet metal parts. In the numerical surface mesh model, baffles are
represented by shell elements, which have fluid volume on both sides.
Once the baseline model is prepared, you can define morph volumes, morph geometry, create design shapes and run DOE
studies. These tool work for both AcuSolve and ultraFluidX-based workflows.
Use the Mesh Controls: Offset tool
to refine mesh within a given distance from the entire vehicle body.
As opposed to the Mesh Controls: Box tool, which creates a box-shaped refinement zone, the mesh
refinement patterns of the Mesh Controls: Offset tool follow the contour of the body itself. This creates
refinement around the body where it is needed most, eliminating unnecessary refinement
that may result from a box-shaped zone.
From the Setup ribbon, click the
Mesh Controls
tool.
From the secondary tool set, click the body of the Offset tool.
Select a point on the model body.
Choose whether to define the refinement zone based on distance or layers using
the drop-down menu in the microdialog.
Specify the distance or number of layers for the refinement zone.
Enter a value in the microdialog.
Drag the slider up and down.
Figure 3.
Enter a value for Level.
Note: All mesh controls in the model are defined relative to the far field size,
and must be a power of 2 of the far field size. For example, if you define a
far field mesh size of 1 m, the available refinement sizes will be 0.5,
0.25, 0.125, etc
Tip:
Consecutively clicking
generates multiple refinement zones with increasing dimensions.
Modify the refinement zone's dimensions in the Property Editor.
