Position the Car
Use the Move tool to position the car inside of the wind tunnel.
When positioning the car, it is advisable to change the view to orthographic projection using the icon on the View Controls toolbar.
  1. In the Model Browser, click the top-most assembly to select the entire car.
  2. From the Home group, click the Move tool.
    The Move tool will initially be positioned at the centroid of selected entities.
  3. Click a graphical manipulator then do one of the following:
    • Drag the graphical manipulator to translate or rotate entities in the selected direction(s).
    • Enter a precise value in the microdialog and press Enter.
    To Do This
    Translate along an axis Click the X, Y, or Z arrow.
    Figure 3.
    Translate along a plane Click the XY, XZ, or YX plane square.
    Figure 4.
    Translate freely in 3D space Click the origin of the Move tool.
    Figure 5.
    Tip: Use the icons in the microdialog to align the tool to a part or the global axes.
    Rotate around an axis Click a curved arrow.
    Figure 6.
    Rotate freely Click at the tip of the X, Y, or Z arrow and drag. In the external aero setup environment, an axis line appears and the unresolved rotation is prompted on release.
    Figure 7.
  4. Position the front end of the car at a certain distance from the inflow.
    1. Position the Move tool at the front end of the car by holding the Shift key, clicking on the origin of the tripod, then dragging it while pressing the left mouse button.
      Figure 8.
    2. Once the triad is positioned, release the left mouse button and Shift key, then click on the center of the origin to open the dialog for the x, y, and z coordinate of the origin.
      The x coordinate of the tripod's origin represents the absolute position of the car nose.
    3. Type the desired distance into the x text field to move the car to the correct position.
    A similar technique can be used if a certain ride height, distance of the fender lip to the ground or underbody to the ground needs to be modeled. A reasonable positioning in the z direction, upwards, is when the wheels are slightly penetrating the ground of the wind tunnel.
    Figure 9.
