Define Mesh Controls
Use the Mesh dialog to define mesh settings.
  1. From the Setup ribbon, click the Advanced meshing parameters tool.
    The Mesh dialog opens.
  2. In the Mesh dialog, define the desired mesh controls settings.
    Triangle plinth
    Create a plinth surface around single voxel gaps near the wind tunnel ground.
    Triangle splitting
    Activate triangle splitting of surfaces.
    If Triangle splitting is enabled, the following edge length controls apply:
    Maximum relative edge length
    Triangle edge length relative to the local voxel size.
    Maximum absolute edge length
    Maximum triangle edge length.
    Far field element size
    Coarsest element size.
    Refinement level transition layers
    Minimum number of elements to create between mesh refinement zones.
  3. Click Close.
