Flux in SimLab : 2D Examples
| Solution | Example | Description | Illustration |
| 2D Transient Magnetic |
Brushless IPM motor | The studied device, a brushless AC embedded permanent magnet motor
presented in the figure in the right, includes the following elements:
Brushless SPM motor |
The studied device, a brushless DC motor with surface permanent magnet, includes the following elements:
Multi-physics (EM, NVH, CFD) Analysis of a 75 kW PMSM - Motor Mode |
The studied device, a 75-kW permanent magnet synchronous machine, is
running in motor mode. As presented in the figure in the right, it
EM-CFD Coupling Analysis of a 75 kW PMSM (Air Cooling) - Generator Mode |
running in generator mode. As presented in the figure in the right, it
| 2D Transient Magnetic | Synchronous Reluctance Motor (SynRM) | The studied device, a synchronous reluctance motor, is running in
motor mode. As presented in the figure in the right, it includes the
following elements:
| 2D Transient Magnetic | Wound Rotor Synchronous Motor (WRSM) | The studied device, a wound rotor synchronous motor, is running in
following elements:
| 2D Axi Transient Magnetic | Actuator | The studied device includes the following elements:
