Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
The application Home tab provides an option to connect to Altair One, view recent activities, launch Altair Drive application, open the mounted Altair Drive files location in Windows Explorer and view the preferred log details.
View the files or folders that are shared by other users.
You can modify the shared files or folders based on the permissions provided to
you.
In the case of concurrent save action on the same content by different users,
only the updates committed by the first user is synched between Altair Drive and the mounting location.
The updates of other users will fail but will be temporarily cached in the Altair Drive
Desktop cache location. Also, an error message will be posted in the
other user activity window of the application and the log file. The file updates
will be available for three days, after which the cache file will be automatically
deleted. User would need to validate the latest file updates in Altair Drive and make the necessary
changes.
Note: You must be connected to Altair One to access the latest file
contents of a shared file or folder.
On the Home tab, click Open
MyFiles.
Your mounted Altair
Drive files are displayed in a Windows Explorer. Figure 1. Mounted Altair Drive
Click on the mounted drive of your profile.
The Windows Explorer displays MyFiles and SharedWithMe folders. Figure 2. Mounted Altair Drive-Profile
Click SharedWithMe folder to view the files or folders
A list of the user folders who have shared files or folders with you is
displayed. Figure 3. Altair Drive - Shared Users Folder
Double-click the user folder to view the files that are shared with you.
