Build specific search for a file type, combine multiple search values by selecting correct operators (=, Like, or
Is) and values (file name, file extension, metadata).
The application Home tab provides an option to connect to Altair One, view recent activities, launch Altair Drive application, open the mounted Altair Drive files location in Windows Explorer and view the preferred log details.
Share your files or folders with another user or team from Windows
Explorer.
The following are the defined fixed roles for sharing a file or folder:
Owner: User can execute, view, read, update, download
it to your local system, mark it as favorite, share it an another user, and
delete the shared files.
Editor: User can execute the file, view, read,
update, download it to you local system, and mark it as favorite.
Viewer: User can view, read, download files to you
local system, and also mark it as favorite.
You can always add or remove roles from a fixed role as necessary, however this
creates a Custom role.
Note: You must be connected to Altair One to share a file or folder.
The Profile should be connected to Altair
One to share a file.
On the Home tab, click Open
MyFiles.
Your mounted Altair Drive files are displayed in a Windows
Explorer.
Right-click the file or a folder and select Altair
One.
Select Share.
The Share dialog box is displayed.
To share with a user:
For Add User, begin entering the user name of a
user with whom you would like to share the file or folder.
A list of matching user names are displayed.
Select a user from the list.
Repeat the two previous steps to share the file or folder with
additional users.
To share with a team:
For Add Team, begin entering the name of the
team with whom you would like to share the file or folder.
A list of matches are displayed.
Select a team from the list.
additional teams.
For Select Role, assign permissions to the file or
folder by choosing a role.
Editor: User can execute, read, update, download,
add as a favourite, and view details.
Owner: Provides full permissions for a user. This
includes Editor role and additionally, user can share and delete the file or
folder.
Viewer: User can read, view, download, and add it
as their favourite file or folder.
Custom: This role appears when you modify the
default permissions of the above default roles.
Click Submit.
The selected file or folder is shared and a notification is
displayed.
