ProMan allows also the assignment of time-variant
behavior to an antenna. The antenna moves in the same way as the object group does to which
the antenna is assigned, or moves as specified along the trajectory to which it is assigned.
The trajectory can be edited at this stage.
The assignment of the antenna to a certain group or trajectory can be made in the cell
dialog.
Figure 1. Setting the location of the antenna as time-variant in the
Cell dialog.
Note: Time-variant settings are available if the time-variant simulation is
enabled on the Edit Project Parameter dialog
(Simulation tab).
