Where Used
WA allows you to quickly view all products that are manufactured by an organization in which a specific part pr assembly is used.
icon. This feature is available in the following
areas of the software.- .
| Operation | Description |
| PULL |
Pull the attribute values from the part and snapshot selected in the Where Used results to the currently active part. You can pull the data from another snapshot if you have permissions to modify the active snapshot and the status of the snapshot allows modification of the parts. |
| PUSH |
Push the attribute values from the currently active part to the part and snapshot selected in the Where Used results. Pushing data from the active part to another snapshot is
allowed only if:
