View Modified Parts
The Modified Parts functionality facilitates filtering and viewing of the parts that were modified within a specified date range.
Discover new features available Weight Analytics version 2025.
Weight & Balance Engineering, also known as Mass Properties Engineering, is the technical discipline which refers to the prediction, determination, management and tracking of the weight, Center of Gravity, and Moment of Inertia for a new product.
Altair's Weight Analytics (WA) incorporates the weight and balance as well as cost information of a product in the design and development process.
The Home page is the first page that you see after logging into WA.
WA supports logging in using Single sign-on user authentication.
The Weight Analytics user interface comprises icons that allow you to navigate and execute various functionalities in the workspace..
The Home Page allows you to search for a Product within the Program tree.
Weight Analytics allows you to view or change the System of Units and Currency that will apply to a selected Program or Product.
WA allows you to quickly view all products that are manufactured by an organization in which a specific part pr assembly is used.
WA allows you to attach external documents to single parts at the Concept, Development, Parts Catalog, and Analytics levels, and similar to document attachments at the Program, Version, Variant, and Product levels. You can upload and group the files under three pre-defined categories such as General, Technical, and Planning. You can also upload files at the top level outside of these three categories.
The Multiple Item Selection functionality facilitates the selection of multiple parts so that you can modify the attributes (maturity, for example) of the selected parts with common attribute values. When you edit multiple parts at the same time, all the selected parts are updated with the same values.
Weight Analytics offers a context-sensitive right-click and an expand/collapse on the nodes functionality on all pages including the Home page and the Product Selection page in the tree view.
WA allows you to perform advanced searches at the Concept, Development, Analytics, and Parts Catalog levels to search for parts in the BoM that belong to each product.
In multiple areas of WA, the parts of the products that exist in the database are displayed in the Grid View.
The Programs > Management page allows you to create and manage programs in the database. A Program structure includes Versions, Variants, and Products in the order of hierarchy.
In WA, a Concept is similar to a Product in development, with a few key differences.
This section allows you to manage the Bills of Material (BoMs) available for each Product in the system.
WA provides a powerful and comprehensive mission simulation module which allows you to calculate the evolution of the weight during the flight and to monitor how this curve changes over the product life cycle.
The Analytics section of WA allows you to create reports and charts and they are available in a dashboard.
This section allows you to manage parts, their weight and cost, and compare assemblies.
Functional views are the granular views of a Product.
This section describes how to use the Admin Interface to manage security options.
The Currency section of Weight Analytics allows you to manage currencies and their exchange rates using historical methods.
Customization allows you to export Snapshot grid details, add Refrence System Catalogs, create and manage departments, and so on.
The Help section of Weight Analytics provides information about the product version, Help contents, and so on.
WA allows you to view or edit your profile settings and general information and change your login password.
As a WA Administrator, you can insert a warning broadcast message that is immediately visible to all users connected to WA.
icon in the From field.
icon in the To field.
© 2024 Altair Engineering, Inc. All Rights Reserved.
