Tutorial: Working with Extensions
Learn how to add and install an extension through the Extension Manager.
This tutorial shows you how to add, install and use a ScopeStatus extension to set all scopes in a diagram to be on or off at once.
Files for This Tutorial
ScopeStatus directory
Add and Install the Extension
- Select .
Select the Add Extension button.
Select the folder where the extension is saved:
<installation_directory>/tutorials/ScopeStatus.
The extension is added to the Extension Manager.
Select the Load button on the extension and slide
right.
The extension is now installed and is accessible from the ribbon:
Inspect the Extension Details
Click the Details button on the ScopeStatus
extension.
Review the information such as the author and version.
Select the View Documentation link and review the
information that is available in the extension folder.
Apply the Extension to a Model
- Open a model that includes scope blocks, for example: .
On the ScopeStatus ribbon, click the Off icon.
Verify that the status of the scopes is Off.
Click the On icon.
Verify that the status of the scopes is On.
You've successfully applied the ScopeStatus extension to your model!
