model_diode
Junction Diode model redefinition
Spice/Analog/Basic/models
.model definitionParameters
sp_mname | Model Name | The model name of the new model that the user wants to create | String | |
sp_D | D | String | ||
sp_level | Diode level selector | Scalar | ||
sp_is | Saturation current | Scalar | ||
sp_jsw | Sidewall Saturation current | Scalar | ||
sp_rs | Ohmic resistance | Scalar | ||
sp_trs | Ohmic resistance 1st order temp. coeff. | Scalar | ||
sp_trs2 | Ohmic resistance 2nd order temp. coeff. | Scalar | ||
sp_n | Emission Coefficient | Scalar | ||
sp_ns | Sidewall emission Coefficient | Scalar | ||
sp_tt | Transit Time | Scalar | ||
sp_ttt1 | Transit Time 1st order temp. coeff. | Scalar | ||
sp_ttt2 | Transit Time 2nd order temp. coeff. | Scalar | ||
sp_cjo | Junction capacitance | Scalar | ||
sp_vj | Junction potential | Scalar | ||
sp_m | Grading coefficient | Scalar | ||
sp_tm1 | Grading coefficient 1st temp. coeff. | Scalar | ||
sp_tm2 | Grading coefficient 2nd temp. coeff. | Scalar | ||
sp_cjp | Sidewall junction capacitance | Scalar | ||
sp_php | Sidewall junction potential | Scalar | ||
sp_mjsw | Sidewall Grading coefficient | Scalar | ||
sp_ikf | Forward Knee current | Scalar | ||
sp_ikr | Reverse Knee current | Scalar | ||
sp_nbv | Breakdown Emission Coefficient | Scalar | ||
sp_area | Area factor | Scalar | ||
sp_pj | Perimeter factor | Scalar | ||
sp_tlev | Diode temperature equation selector | Scalar | ||
sp_tlevc | Diode temperature equation selector | Scalar | ||
sp_eg | Activation energy | Scalar | ||
sp_xti | Saturation current temperature exp. | Scalar | ||
sp_cta | Area junction temperature coefficient | Scalar | ||
sp_ctp | Perimeter junction capacitance temperature coefficient | Scalar | ||
sp_tpb | Area junction potential temperature coefficient | Scalar | ||
sp_tphp | Perimeter junction potential temperature coefficient | Scalar | ||
sp_jtun | Tunneling saturation current | Scalar | ||
sp_jtunsw | Tunneling sidewall saturation current | Scalar | ||
sp_ntun | Tunneling emission coefficient | Scalar | ||
sp_xtitun | Tunneling saturation current exponential | Scalar | ||
sp_keg | EG correction factor for tunneling | Scalar | ||
sp_fc | Forward bias junction fit parameter | Scalar | ||
sp_fcs | Forward bias sidewall junction fit parameter | Scalar | ||
sp_bv | Reverse breakdown voltage | Scalar | ||
sp_ibv | Current at reverse breakdown voltage | Scalar | ||
sp_tcv | Reverse breakdown voltage temperature coefficient | Scalar | ||
sp_fv_max | maximum voltage in forward direction | Scalar | ||
sp_bv_max | maximum voltage in reverse direction | Scalar | ||
sp_Spice | Additional Spice Parameters | String |
