LinearSpeedDependentForce
Linear dependency of force versus speed
Modelica/Mechanics/Translational/Sources
Model of force, linearly dependent on velocity of flange.
Parameter ForceDirection chooses whether direction of force is the same in both directions of movement or not.
LinearSpeedDependentForce_0
mo_useSupport
useSupport
= true, if support flange enabled, otherwise implicitly grounded
Number
0
1
mo_f_nominal
f_nominal
Nominal force (if negative, force is acting as load in positive direction of motion)
Scalar
mo_ForceDirection
ForceDirection
Same direction of force in both directions of motion
Scalar
true
false
mo_v_nominal
v_nominal
Nominal speed
Scalar
LinearSpeedDependentForce_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
's'
's_support'
'f'
'v'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
flange
implicit
Flange of component
output
1
Port 2
implicit
Support/housing of component
input
mo_useSupport
See Also
