ConstantForce
Constant force, not dependent on speed
    ConstantForce
Modelica/Mechanics/Translational/Sources
Model of constant force, not dependent on velocity of flange.
Please note:
Positive force accelerates in positive direction of movement, but brakes in reverse direction of movement.
Negative force brakes in positive direction of movement, but accelerates in reverse direction of movement.
ConstantForce_0
mo_useSupport
useSupport
= true, if support flange enabled, otherwise implicitly grounded
Number
0
1
mo_f_constant
f_constant
Nominal force (if negative, force is acting as load in positive direction of motion)
Scalar
ConstantForce_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
's'
's_support'
'f'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
flange
implicit
Flange of component
output
1
Port 2
implicit
Support/housing of component
input
mo_useSupport
See Also
