SymmetricPolyphaseCageWinding
Symmetrical rotor cage
Modelica/Magnetic/FundamentalWave/BasicMachines/Components
The symmetric rotor cage model of this library does not consist of rotor bars and end rings. Instead the symmetric cage is modeled by an equivalent symmetrical winding. The rotor cage model consists of phases. If the cage is modeled by equivalent stator winding parameters, the number of effective turns, , has to be chosen equivalent to the effective number of stator turns.
See also
SinglePhaseWinding,SymmetricPolyphaseWinding,SaliencyCageWinding,RotorSaliencyAirGap
SymmetricPolyphaseCageWinding_0
mo_m
m
Number of phases
Scalar
mo_useHeatPort
useHeatPort
Enable / disable (=fixed temperatures) thermal port
Number
0
1
mo_RRef
RRef
Winding resistance per phase at TRef
Scalar
mo_TRef
TRef
Reference temperature of winding
Scalar
mo_alpha20
alpha20
Temperature coefficient of winding at 20 degC
Scalar
mo_alphaRef
alphaRef
Temperature coefficient of winding at reference temperature
Scalar
mo_TOperational
TOperational
Operational temperature of winding
Scalar
mo_Lsigma
Lsigma
Cage stray inductance
Scalar
mo_effectiveTurns
effectiveTurns
Effective number of turns
Scalar
mo_nBase
nBase
Number of base systems
Scalar
SymmetricPolyphaseCageWinding_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'abs_V_m'
'arg_V_m'
'abs_Phi'
'arg_Phi'
'i'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
port_p
implicit
Positive magnetic port of fundamental wave machines
input
1
port_n
implicit
Negative magnetic port of fundamental wave machines
output
1
Port 3
implicit
Heat ports of winding resistor
input
mo_useHeatPort
See Also
