ConstantMagneticPotentialDifference
Constant magnetomotive force
Modelica/Magnetic/FluxTubes/Sources
Magnetic circuits under steady-state conditions, i.e., with stationary magnetic fields (change of magnetic flux dΦ/dt = 0) can be described with constant sources of a magnetic potential difference or magnetomotive force (mmf). Constant magnetic potential differences are imposed by
  • coils with stationary current (di / dt = 0) and
  • permanent magnets modelled with Thévenin's equivalent magnetic circuit.
For modelling of reluctance actuators with this source component it is assumed that the armature is fixed so that no motion-induced flux change dΦ/dt can occur.
ConstantMagneticPotentialDifference_0
mo_V_m
V_m
Magnetic potential difference
Scalar
ConstantMagneticPotentialDifference_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'Phi'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
port_p
implicit
Positive magnetic port
input
1
port_n
implicit
Negative magnetic port
output
1
See Also
