IdealCommutingSwitch
Polyphase ideal commuting switch
Modelica/Electrical/QuasiStatic/Polyphase/Ideal
Contains m single-phase ideal commuting switches (Modelica.Electrical.QuasiStatic.SinglePhase.Ideal.IdealCommutingSwitch).
Use with care:This switch is only intended to be used for structural changes, not fast switching sequences, due to the quasi-static formulation.
IdealCommutingSwitch_0
mo_m
m
Number of phases
Scalar
mo_Ron
Ron
Closed switch resistance
Vector
mo_Goff
Goff
Opened switch conductance
Vector
mo_mh
mh
Number of heatPorts=number of phases
Scalar
mo_useHeatPort
useHeatPort
= true, if all heat ports are enabled
Number
0
1
mo_T
T
Fixed device temperatures if useHeatPort = false
Vector
IdealCommutingSwitch_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
control
implicit
true => p--n2 connected, false => p--n1 connected
input
1
plug_p
implicit
input
2
plug_n2
implicit
output
1
plug_n1
implicit
output
2
Port 5
implicit
Conditional heat ports
input
mo_useHeatPort
See Also
