ThermalAmbientSMEE
Thermal ambient for synchronous machine with electrical excitation
    ThermalAmbientSMEE
Modelica/Electrical/Machines/Thermal/SynchronousMachines
Thermal ambient for synchronous machines with electrical excitation to prescribe winding temperatures either constant or via signal connectors.Additionally, all losses = heat flows are recorded.
ThermalAmbientSMEE_0
mo_useDamperCage
useDamperCage
Enable / disable damper cage
Number
0
1
mo_m
m
Number of stator phases
Scalar
mo_useTemperatureInputs
If true, temperature inputs are used; else, temperatures are constant
Number
0
1
mo_Ts
Ts
Temperature of stator windings
Scalar
mo_Tr
Tr
Temperature of damper cage (optional)
Scalar
mo_Te
Te
Temperature of excitation
Scalar
ThermalAmbientSMEE_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'Q_flowStatorWinding'
'Q_flowStatorCore'
'Q_flowRotorCore'
'Q_flowStrayLoad'
'Q_flowFriction'
'Q_flowRotorWinding'
'Q_flowExcitation'
'Q_flowTotal'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
thermalPort
implicit
input
1
Port 2
implicit
input
Port 3
implicit
input
mo_useTemperatureInputs&&mo_useDamperCage
Port 4
implicit
input
See Also
