InertialDelaySensitive
Provide the input as output if it holds its value for a specific amount of time
Modelica/Electrical/Digital/Delay
Provides the input as output delayed by Tdel if the input holds its value for a longer time than Tdel.If the time is less than Tdel the initial value y0 holds.
The delay Tdel depends on the values of the signal change. To calculate Tdel, the DelayTable specified inDigital.Tables is used. If the corresponding value is 1, then tLH is used, if it is -1, then tHLis used, if it is zero, the input is not delayed.
InertialDelaySensitive_0
mo_tLH
tLH
rise inertial delay
Scalar
mo_tHL
tHL
fall inertial delay
Scalar
mo_y0
y0
initial value of output
Structure
mo_y0/choice1
U Uninitialized
Number
0
1
mo_y0/choice2
X Forcing Unknown
Number
0
1
mo_y0/choice3
0 Forcing 0
Number
0
1
mo_y0/choice4
1 Forcing 1
Number
0
1
mo_y0/choice5
Z High Impedance
Number
0
1
mo_y0/choice6
W Weak Unknown
Number
0
1
mo_y0/choice7
L Weak 0
Number
0
1
mo_y0/choice8
H Weak 1
Number
0
1
mo_y0/choice9
- Do not care
Number
0
1
mo_y_auxiliary
y_auxiliary
y_auxiliary
Structure
mo_y_auxiliary/fixed
fixed
Cell of scalars
true
false
mo_y_auxiliary/start
start
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''U''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''X''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''0''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''1''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''Z''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''W''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''L''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''H''')
FromModelica('Modelica.Electrical.Digital.Interfaces.Logic.''-''')
'y0'
mo_y_old
y_old
y_old
Structure
mo_y_old/fixed
fixed
Cell of scalars
true
false
mo_y_old/start
start
'y0'
InertialDelaySensitive_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'delayTime'
'lh'
't_next'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
x
implicit
Connector of Digital input signal
input
1
y
implicit
Connector of Digital output signal
output
1
See Also
