ControlledCloserWithArc
Controlled ideal electrical closer with simple arc model
Modelica/Electrical/Analog/Ideal
This model is an extension to the ControlledIdealClosingSwitch.
For details of the arc effect, see partial model IdealSwitchWithArc.
ControlledCloserWithArc_0
mo_level
level
Switch level
Scalar
mo_Ron
Ron
Closed switch resistance
Scalar
mo_Goff
Goff
Opened switch conductance
Scalar
mo_V0
V0
Initial arc voltage
Scalar
mo_dVdt
dVdt
Arc voltage slope
Scalar
mo_Vmax
Vmax
Max. arc voltage
Scalar
mo_useHeatPort
useHeatPort
= true, if heatPort is enabled
Number
0
1
mo_T
T
Fixed device temperature if useHeatPort = false
Scalar
mo_T_heatPort
T_heatPort
T_heatPort
Structure
mo_T_heatPort/fixed
fixed
Cell of scalars
true
false
mo_T_heatPort/start
start
Cell of scalars
mo_off
off
off
Structure
mo_off/fixed
fixed
Cell of scalars
true
false
mo_off/start
start
Cell of scalars
true
false
mo_quenched
quenched
quenched
Structure
mo_quenched/fixed
fixed
Cell of scalars
true
false
mo_quenched/start
start
Cell of scalars
true
false
mo_tSwitch
tSwitch
tSwitch
Structure
mo_tSwitch/fixed
fixed
Cell of scalars
true
false
mo_tSwitch/start
start
Cell of scalars
ControlledCloserWithArc_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'v'
'i'
'LossPower'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
p
implicit
Positive electrical pin
input
1
n
implicit
Negative electrical pin
output
1
control
implicit
Control pin: control.v > level switch closed, otherwise switch open
input
2
Port 4
implicit
Conditional heat port
input
mo_useHeatPort
See Also
