VariableConductor
Ideal linear electrical conductor with variable conductance
    VariableConductor
Modelica/Electrical/Analog/Basic
The linear conductor connects the branch voltage v with the branch current i by
i = G*v
The Conductance G is given as input signal.
Attention!!!
It is recommended that the G signal should not cross the zero value. Otherwise depending on the surrounding circuit the probability of singularities is high.
VariableConductor_0
mo_T_ref
T_ref
Reference temperature
Scalar
mo_alpha
alpha
Temperature coefficient of conductance (G_actual = G/(1 + alpha*(T_heatPort - T_ref))
Scalar
mo_useHeatPort
useHeatPort
=true, if heatPort is enabled
Number
0
1
mo_T
T
Fixed device temperature if useHeatPort = false
Scalar
mo_T_heatPort
T_heatPort
T_heatPort
Structure
mo_T_heatPort/fixed
fixed
Cell of scalars
true
false
mo_T_heatPort/start
start
Cell of scalars
VariableConductor_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'v'
'i'
'LossPower'
'G_actual'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
p
implicit
Positive electrical pin
input
1
n
implicit
Negative electrical pin
output
1
G
implicit
input
2
Port 4
implicit
Conditional heat port
input
mo_useHeatPort
See Also
