Transformer
Transformer with two ports
    Transformer
Modelica/Electrical/Analog/Basic
The transformer is a two port. The left port voltage v1, left port current i1, right port voltage v2 and right port current i2 are connected by the following relation:
         | v1 |         | L1   M  |  | i1' |         |    |    =    |         |  |     |         | v2 |         | M    L2 |  | i2' |
L1, L2, and M are the primary, secondary, and coupling inductances respectively.
Transformer_0
mo_i1
i1
i1
Structure
mo_i1/fixed
fixed
Cell of scalars
true
false
mo_i1/start
start
Cell of scalars
mo_i2
i2
i2
Structure
mo_i2/fixed
fixed
Cell of scalars
true
false
mo_i2/start
start
Cell of scalars
mo_L1
L1
Primary inductance
Scalar
mo_L2
L2
Secondary inductance
Scalar
mo_M
M
Coupling inductance
Scalar
Transformer_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'v1'
'v2'
'dv'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
p1
implicit
Positive electrical pin of port 1
input
1
n1
implicit
Negative electrical pin of port 1
output
1
p2
implicit
Positive electrical pin of port 2
input
2
n2
implicit
Negative electrical pin of port 2
output
2
See Also
