SaturatingInductor
Simple model of an inductor with saturation
Modelica/Electrical/Analog/Basic
This model approximates the behaviour of an inductor with the influence of saturation, i.e.,the value of the inductance depends on the current flowing through the inductor (Fig. 1).The inductance decreases as current increases. Note, that hysteresis is not taken into account.
The approximation of the flux linkage is based on the atan
function with an additional linear term,as shown in Fig. 2:
Psi = Linf*i + (Lzer - Linf)*Ipar*atan(i/Ipar)L = Psi/i = Linf + (Lzer - Linf)*atan(i/Ipar)/(i/Ipar)
This approximation is with good performance and easy to adjust to a given characteristic with only four parameters (Tab. 1).
Variable | Description |
Inom . | Nominal current |
Lnom | Nominal inductance at nominal current |
Lzer | Inductance near current = 0; Lzer has to be greater than Lnom |
Linf | Inductance at large currents; Linf has to be less than Lnom |
The parameter Ipar
is calculated internally from the relationship:
Lnom = Linf + (Lzer - Linf)*atan(Inom/Ipar)/(Inom/Ipar)
The flux slope in Fig. 2 is equal to Lzer
for small currents.The limit of the flux slope is Linf
as the current i
approaches infinity.The nominal flux is indicated by the product of the nominal inductance Lnom
and the nominal current Inom
mo_i | i | i | Structure | |
mo_i/fixed | fixed | Cell of scalars | true | |
mo_i/start | start | Cell of scalars | ||
mo_Lact | Lact | Lact | Structure | |
mo_Lact/fixed | fixed | Cell of scalars | true | |
mo_Lact/start | start | Cell of scalars | ||
mo_Inom | Inom | Nominal current | Scalar | |
mo_Lnom | Lnom | Nominal inductance at Nominal current | Scalar | |
mo_Lzer | Lzer | Inductance near current=0 | Scalar | |
mo_Linf | Linf | Inductance at large currents | Scalar | |
mo_Ipar | Ipar | Scalar |
mo__modifiers/varname | Variable name | Cell of strings | 'v' | |
mo__modifiers/value | Value |
p | implicit | Positive electrical pin | input | 1 |
n | implicit | Negative electrical pin | output | 1 |
