Conductor
Ideal linear electrical conductor
    Conductor
Modelica/Electrical/Analog/Basic
The linear conductor connects the branch voltage v with the branch current i by i = v*G. The Conductance G is allowed to be positive, zero, or negative.
Conductor_0
mo_G
G
Conductance at temperature T_ref
Scalar
mo_T_ref
T_ref
Reference temperature
Scalar
mo_alpha
alpha
Temperature coefficient of conductance (G_actual = G_ref/(1 + alpha*(T_heatPort - T_ref))
Scalar
mo_useHeatPort
useHeatPort
=true, if heatPort is enabled
Number
0
1
mo_T
T
Fixed device temperature if useHeatPort = false
Scalar
mo_T_heatPort
T_heatPort
T_heatPort
Structure
mo_T_heatPort/fixed
fixed
Cell of scalars
true
false
mo_T_heatPort/start
start
Cell of scalars
Conductor_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
'v'
'i'
'LossPower'
'G_actual'
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
p
implicit
Positive electrical pin
input
1
n
implicit
Negative electrical pin
output
1
Port 3
implicit
Conditional heat port
input
mo_useHeatPort
See Also
