Multiplex5
Multiplexer block for five input connectors
    Multiplex5
Modelica/Blocks/Routing
The output connector is the concatenation of the five input connectors.Note, that the dimensions of the input connector signals have to beexplicitly defined via parameters n1, n2, n3, n4 and n5.
Multiplex5_0
mo_n1
n1
Dimension of input signal connector 1
Scalar
mo_n2
n2
Dimension of input signal connector 2
Scalar
mo_n3
n3
Dimension of input signal connector 3
Scalar
mo_n4
n4
Dimension of input signal connector 4
Scalar
mo_n5
n5
Dimension of input signal connector 5
Scalar
Multiplex5_1
mo__nmodifiers
Number of Modifiers
Specifies the number of modifiers
Number
mo__modifiers
Modifiers
Add new modifier
Structure
mo__modifiers/varname
Variable name
Cell of strings
mo__modifiers/attribute
Attribute
Cell of strings
'start'
'fixed'
mo__modifiers/value
Value
u1
implicit
Connector of Real input signals 1
input
1
u2
implicit
Connector of Real input signals 2
input
2
u3
implicit
Connector of Real input signals 3
input
3
u4
implicit
Connector of Real input signals 4
input
4
u5
implicit
Connector of Real input signals 5
input
5
y
implicit
Connector of Real output signals
output
1
See Also
