Multiplex2
Multiplexer block for two input connectors
Modelica/Blocks/Routing
The output connector is the concatenation of the two input connectors.Note, that the dimensions of the input connector signals have to beexplicitly defined via parameters n1 and n2.
mo_n1 | n1 | Dimension of input signal connector 1 | Scalar | |
mo_n2 | n2 | Dimension of input signal connector 2 | Scalar |
mo__modifiers/value | Value |
u1 | implicit | Connector of Real input signals 1 | input | 1 |
u2 | implicit | Connector of Real input signals 2 | input | 2 |
y | implicit | Connector of Real output signals | output | 1 |
