Rotate
The Rotate Image block lets you rotate an image at a specified angle.
ComputerVision/Images/Transformations/Geometric
useInput | Use inputs | Use inputs to define the angle. | Number | 0 |
angle | Angle (deg) | Specifies rotation angle in degree. | Scalar | |
externalActivation | External activation | This parameter defines if the block receives or inherits an external activation. When External Activation is used, an additional activation port is added to the block. Default is OFF. | Number | 0 |
src | explicit | input | 1 | |
image | explicit | output | 1 | |
Port 3 | explicit | input | useInput | |
Port 4 | activation | input | externalActivation |
