Organize the User Material Library
Organize the User material library, which contains custom materials you saved, by creating your own material packages and categories.
  1. Select the Rendering tab.
  2. The Material Library appears.
  3. Right-click User.
  4. Click Create Package.
  5. Enter a name for your package.
  6. Right-click your package, and then click Create Category.
  7. To add a material to your category, drag the desired material onto your category.
  8. In the dialog box, click Copy.
    The material will now be in your package.
