Autoaxis Mapping
Project the texture or label onto the object in the shape of an unfolded cube.
Position the
texture or
label:
To Do this Move the origin Drag the origin. Translate Drag the grid. Flip Select Flip Horizontal or Flip Vertical. Rotate - Drag the arrows.
- Type a X Rotation, Y Rotation, or Z Rotation.
- Select Free Rotation, and then drag the sphere.
Align to an axis Select Snap to Axis (Shift), and then drag it to the axis. Center Click Center. Note: To return to the previous position, click Revert. -
Resize the
texture or label:
To Do this Scale - Type a Global Size.
- Type Size X, Size Y, or Size Z.
- Select Free Scale (Alt), and then drag the edges of the box.
Define the aspect ratio Type an Image Aspect Ratio. You can also select Keep Aspect.
Fit to surface Click Fit.
Note: To reset all parameters to the default values, click
Reset.
