Defining the Format in Data Sources
You can select the format to use in the connector for Azure, Google Cloud, Microsoft OneDrive, Rapidminer - Data Catalog, S3, Text Entry, and Web Data data sources.
  1. Select the Data Type. For example:
    • JSON
      If JSON is selected, enter the Record Path which allows the identification of multiple records within the JSON document (e.g., myroot.items.item) and select the Array Handling setting.
    • Text
      If Text is selected, confirm the Decimal Separator, Text Qualifier, Column Delimiter, and if the first row of the message includes column headings.
    • XML
      If XML is selected, enter the Record XPath which allows the identification of multiple records within the XML document (e.g., //myroot/items/item).
    • Excel (xlsx) or Excel (xls)
      For Excel file type, select the required sheet and adjust the headers on first row, if needed.
    • Arrow IPC
    • SVG
      Select Include Transparent Paths checkbox if required.
      NOTE:
      • The Decimal Separator setting is not available on the Web Data and Text Entry connectors.
      • In the SVG parser, columns listing is not displayed.
    • RMHDF5
      This data type is only available in the RapidMiner – Data Catalog connector.
  2. Define or set the columns that represent the sections of the file.
    Property Description
    Name
    JsonPath/Column Index/XPath
    The JsonPath/Column Index/XPath of the source schema.
    Date Format
    Enabled
    Determines whether the message field should be processed.
    NOTE: To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of uppercase S. There can be no additional characters following them. For example: yyyy-MM-dd HH:mm:ss.SSSSSS.
    To delete a column, select  or for all the column entries, select the topmost , then click .
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
