Connector for Microsoft OneDrive
The connector for OneDrive allows you to access and use your personal files hosted on Microsoft OneDrive.
To use this connector, perform the following prerequisites:
Then configure the Panopticon.properties file located in the AppData folder (i.e., /etc/panopticon/appdata) with the values generated from these prerequisites:
Property
OneDrive connector
Attribute
connector.onedrive.client.id
Application (client) ID assigned by the Azure administration portal.
Default Value
Property
OneDrive connector
Attribute
connector.onedrive.client.secret
Your application’s client secret created in the application registration portal.
Default Value
Property
OneDrive connector
Attribute
connector.onedrive.root.url
The Microsoft Graph API root URL.
Default Value
https\://graph.microsoft.com/v1.0/me/drive/root
Property
OneDrive connector
Attribute
connector.onedrive.tenant.id
Controls who can sign into the application. The allowed values are:
  • common - for both Microsoft accounts and work or school accounts
  • organizations - for work or school accounts only
  • consumers - for Microsoft accounts only
  • tenant - identifiers such as the tenant ID or domain name
Default Value
Save the updated properties file and restart Tomcat.
  1. Click Login.
    A notification dialog box displays where you may need to enter the login credentials to your Microsoft account. Click Accept to allow permissions.
    Your OneDrive files are now displayed in the list box.
  2. Select the Only Show Know File Types checkbox to narrow down the list based on the supported data types.
  3. Select the OneDrive file. The file name is displayed in the File Path field and the Data Type is updated with its related fields.
  4. Select either the period (.) or comma (,) as the Decimal Separator.
    NOTE: Prepend 'default:' for the elements falling under default namespace.
  5. Click   to the fetch the schema based on the connection details. Consequently, the list of
    columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
  6. You can also opt to load or save a copy of the column definition.
    NOTE: This option is not available for the Excel data type.
  7. Click   to add columns to the OneDrive connection that represent sections of the message. Then enter or select:
    Property Description
    Name
    JsonPath/Column Index/XPath
    The JsonPath/Column Index/XPath of the source schema.
    Date Format
    Enabled
    Determines whether the message field should be processed.
    NOTE: To parse and format times with higher than millisecond precision, the format string needs to end with a period followed by sequence of upper case S. There can be no additional characters following them.
    For example: yyyy-MM-dd HH:mm:ss.SSSSSS
    To delete a column, select  or all the column entries, select the topmost , then click .
Giving Read Access to OneDrive Data Files for Viewers of Your Dashboard
When you share a file in OneDrive with another user, they will be able to view the data of a Panopticon data table that you created from that file as soon as:
  • They can see the file in their personal OneDrive using the browser (Sharepoint.com), under the Shared section
  • If a user has done the login procedure through the OneDrive connector, they will be able to load any file shared with them, regardless of it showing or not under Shared in the Sharepoint.com web view
Users that only have a Viewer role in Panopticon will be able to view the data of a Panopticon data table that you created from a file in your OneDrive, as soon as the user can see the file in their personal OneDrive using the browser (Sharepoint.com), under the Shared section. Until the shared file has been listed there by OneDrive, the user will not be able to load the data through Panopticon.
NOTE: The Viewer user is also required to be authenticated/logged in to Panopticon using the same identity as in OneDrive (i.e., company single-sign-on identity).
(c) 2013-2025 Altair Engineering Inc. All Rights Reserved.
